Bluray with multi channel outputs
northantsbloke34
128
I have an older Denon Av amp which I dont want to change yet so what would be the best Bluray player with multi channel outputs for around £300 to £400 mark.?
Thankyou
f1only
278
Do you want 3D in the future? if not then the Panasonic DMP-BD85 has analog outs Clicky
If you do then the Pany DMP-BDT300 Clicky
Edit: there is the cambridge audio azure 650BD player to add to the mix within your budget
just taken the plunge myself on the panny 85,
have to say am very impressed with the the multi channel outs through a older amp.
This is a bargain at £99.99 using voucher code sonyblu99.
