Bluray player, which one and disc problems? sony360 player?
Im looking at buying my first bluray player and see the sony360 has had good reviews in the past and is at a discounted price in richer sounds? They are offering 2 players one on which is slightly more (£99.99) but is multi region, is it not the case of buying any bluray player and then going on the internet get a multi region hack code and tying it in or doing a software upgrade by putting a disc in to make it multi region if i buy the cheaper model which is locked to our region?
Reading around I also see that certain players seem to have some trouble playing some films in particular Terminator Salvation and many more where the player doesn' t recognise the disc or stops playing half way through etc, some people have said inserting a usb stick into the player stops this or a firmware/software up grade solves these problems and it should no longer happen is this the case? I have a sony is10 home cinema system I take it i can connect my bluray player into this somehow and get good sound and picture quality? Thanks for your help!
Multi region is not always that easy!
I have been using a Sony s350 and it has played every disc i have put in (there have been many !) just keep up with any updates.
i have a 360 and have never had a disc stick and i have around 330 blu ray films
including terminater salveation
as for multiregion on dvd you need to buy a remote of ebay for around £12 which you point at the player or get it already done
multiregion on the blu ray requires a chip or profesional mod which is very expensive and not really worth it
