Bluetooth receiver transmitter?
Anthony1723
Hi hopefully a semi easy one
My setup is a little odd apparently because I use a denon av amp to hook up to turntable and Polk sub - not too bothered about that as it does all I need .. except..
Some of my music is challenging to the ear so I’m looking for a Bluetooth solution to transmit vinyl to my Sony headphones - meaning I can play the challenging stuff easier without winding up the house 🙂
Am looking at this at the moment but not sure it will do what I want:
MEE Audio AF-CH Connect Hub DUAL BT Transmitter & Receiver​
Any thoughts or steer?
Ta in advance 👍🏻
jjbomber
If the Sony headphones are already bluetooth, you only need a transmitter. The headphone output would connect to the transmitter input, assuming your Denon AV amp has a headphone output. If you can let us know the exact models, we can give a better reply.
Reactions: Anthony1723
Anthony1723
Hi my set ups a Denon 1802 with a Polk SW and a denon dp300f turntable.
Got optical in and outs on the back so think I can link a receive /transmit unit that way and run like that?
