Bluesound Node optical in switching query
Witterings
709
426
5,270
Not sure if anyone's tried this but if they have, if I'm using the optical in on a Node, do I have to go into the Bluesound App and switch the input in some way if I want to go from that to using Tidal Connect with the Node as a streamer or will it auto detect what I'm doing / which is playing?
twinkletoes
943
706
5,770
looks like you have to enable it
And streaming should always take priority over any input I would imagine
Witterings
709
426
5,270
Brilliant ... thank you for that, I wonder how well it works in real life.
I have another streamer that's better for groups / multiroom and it'd mean I could use it's optical out into a Node then USB out so they both end up using the same DAC and also the input on my amp and just be easier if it autodetects
