Blu Ray Player
Dermondo
132
Hi all, as previously stated I have just purchased a Samsung LE37B550.
I am all a bit new to the Blu Ray side of home theatre, so I am seeking a bit of guidence of what should I be looking before purchasing a blu ray player and any suggestions of a particular unit would also suffice to go with my new TV.
If anyone else has this particular TV, can I ask what Blu Ray they use please.
Many thanks in advance to all who reply.
ear
118
the only thing I can tell you is that the tv has a bit of motion blurr.I dont know wich will be the best blu ray player to go with.
Dermondo
132
ear:the only thing I can tell you is that the tv has a bit of motion blurr.I dont know wich will be the best blu ray player to go with.
I wonder would this be enhanced with Blu ray then.
ear
118
I actually dont know it a blu ray with some judder is better than a bluray with smooth motion with this tv.
Dermondo
132
ear:I actually dont know it a blu ray with some judder is better than a bluray with smooth motion with this tv.
I suppose it's trial & error to see what looks the best.
