blu ray player to pair with denon 2309
Hems
108
i know the review of this amp wasnt great but I am planning to buy a blu ray player to go alongside it. given that I can afford to get a denon 2500bt or even the sony 5000es do you guys think its not worth going for either of them? I currently use a ps3 but want a high quality player thats good with blu ray discs and cds. any thoughts from anyone and the whf team would be appreciated.
thanks
Hi
The pioneer bdp-lx71 is good with everything I have it and currently £500.00 richersounds bargain briiliant player
Or the Pioneer FD-51 same player as in PQ and Sound but £299.95 from Richer Sounds.
What type of display are you using? To spend that kind of money on a BD spinner, I a) wouldn't do it without a demo to appreciate the differences for myself and b) Would only spend that if I had a higher end big display e.g. Pro Panel, Kuro, 1080p projector. Have you read the last two month's mags? Both are inundated with BD player reviews, which should be online. That said, it is your money but in my opinion, the marginal increase in quality of these players does not justify the cost. The law of diminishing returns springs to mind. I would get out to the dealers and do some side-by-side comparisons rather than listening to online opinion and review only.
If I had £900 burning a hole in my pocket, I would wait and see what
the new Sony players are like e.g. 360. Hopefully the new budget players from Sony and Pioneer will be a step above the current players and have full profile 2.0 (not that anyone needs it), full HD audio decoding (which will be required for some discs), quicker loading times etc. I would then spend the difference on a NAS and Squeezebox and rip all my CD's in lossless format. Since installing
my Squeezeboxes, I have hardly turned the CD player on and now have
access to my entire CD library, internet radio, last.fm and so on.
I personally don't think you would notice a big enough difference to justify the cost. As I said, demo though.
