Hey guys,
I bought a combo of a pair of Mordaunt-Short Aviano 1s and my Denon PMA-510AE amp from Richer Sounds about two years ago now (Specs here for the Denon and here for the Mordaunt-Shorts). I was very happy with the combo at first but the whole setup has been through a bumpy ride - basically several house parties.. I'm not very clued up on troubleshooting these incidents and want to work out whether there could be anything wrong with my setup other than a blown speaker, before I go ahead and start shopping for replacements.
One of my aviano 1s has now been blown TWICE, just recently about a year after replacing the woofer the first time. At the moment the cone has come well away from the rubber, it's a grizzly sight to behold! Last time was similar, though a much smaller part of the cone became detached (which is what causes the rattling). Worse, although it looks absolutely fine, the other also seems to rattle a tiny bit at high volume, though I think it sounds fine at low and medium volume, especially as it sits very near me on my desk.
I'd like some advice on:
1) whether it sounds like my second speaker might be blown
2) whether I'm safe to just replace the one woofer again and continue with this setup
and
3) how I can avoid this happening again, other than buying a subwoofer to use for future parties
I use a turntable with its own preamp and an RCA-jack cable into my laptop mostly for music, that both go direct into the Denon. But I also have a set of CDJs and a mixer that I use - these are what were being used at all the parties, including the ones where my speaker blew. I never allow the output from the mixer to go past halfway, and it's usually quieter than an iPod through the line-in on the Denon at the same volume. I certainly never let the Denon's volume go past about 2-3 o'clock and 99% of the time have it well below halfway.
I thought previously that I might have run into trouble at parties when DJs (some amateur) turned the channel volumes of tracks up so they peaked. Also, rarely, someone has pulled the RCA-jack out (of an iPod or my laptop) without taking the Denon's volume down first, so it makes a god-awful noise. But perhaps what I assume to be the biggest danger to the speakers is my mixer which has a faulty power input - sometimes it suddenly cuts out and then when the power re-connects it makes a very loud popping sound. I assume these are all a classic recipe for a blown speaker, despite my care with volume levels? What could I do to reduce the risk? Other than what I've been recommended a few times to do, which is buy a sub-woofer for the Speaker B output of my Denon to reduce the power going to the Avianos.
My Denon mixer also suffered an accident one party where a sugary drink was spilled on it while it was playing pretty loudly. I'm not 100% sure if that's still affecting the setup - I cleaned the circuitry very carefully and dried it out for a long time after which it seemed to be working perfectly. The only trouble I've had with it seems to be a regular dust build up in the volume control which sometimes causes a quiet static noise, but this pre-dates the spill. Could this be a contributing factor, or could the rattling I hear have anything to do with the mixer instead of the better-sounding speaker?
As a sort of icing on the cake, I've noticed that sometimes I get a small electric shock from touching the RCA-jack or even the metal face of my DJ mixer. Could there be an issue with how I'm powering everything? I do use a couple of extension leads, and here at the moment in Amsterdam I'm also transforming everything from UK plugs to EU sockets.As you can imagine, I'm reluctant to go ahead and replace another woofer in case this happens again, and especially if both speakers are blown, in which case I'd rather just get a new set than replace the drivers for around £90, for which I could just get a new, probably better, pair.I would normally take the whole lot into Richer Sounds but for one I'm in Amsterdam without a car, and also the last time I took the speakers in they swore they weren't broken, even though I'm 99% sure at least one had been partially damaged by that point (it has been mildly rattling for some months, but only just exacerbated to the extent I've described above).Anyway sorry for the essay, I hope someone can point me in the right direction!Much obliged!
and
