jonathanRD said:To bi-wire speakers you will usually have the following configuration - each speaker cable will have four wires - lets say red, black, green and purple. If the red and green wires are connected to the red posts on the speaker, the red and green wires will be joined together at the amp end to make a single connection to the amps red post. And likewise the black and purple wires will connect individually to the black posts on the speaker, but will be joined together the amp end to make a single connection to the amps black post. So in summary, at the amp end the four wires are joined in pairs, at the speaker end the four wires are individual.
davedotco said:jonathanRD said:To bi-wire speakers you will usually have the following configuration - each speaker cable will have four wires - lets say red, black, green and purple. If the red and green wires are connected to the red posts on the speaker, the red and green wires will be joined together at the amp end to make a single connection to the amps red post. And likewise the black and purple wires will connect individually to the black posts on the speaker, but will be joined together the amp end to make a single connection to the amps black post. So in summary, at the amp end the four wires are joined in pairs, at the speaker end the four wires are individual.
Nicely explained.
However you failed to point out that, bi-wiring, will make absolutely no difference to the percieved sound quality.
To the OP. If you need to buy new speaker cable, get some decent thick OFC copper cables, Van Damme perhaps.
jonathanRD said:davedotco said:jonathanRD said:To bi-wire speakers you will usually have the following configuration - each speaker cable will have four wires - lets say red, black, green and purple. If the red and green wires are connected to the red posts on the speaker, the red and green wires will be joined together at the amp end to make a single connection to the amps red post. And likewise the black and purple wires will connect individually to the black posts on the speaker, but will be joined together the amp end to make a single connection to the amps black post. So in summary, at the amp end the four wires are joined in pairs, at the speaker end the four wires are individual.
Nicely explained.
Haha - no I didn't fail - I just stayed well clear of that one*biggrin*
BigH said:Biwiring makes little difference IMO, in fact it can introduce phase problems, so I recommend not bothering, make sure the links between the speaker terminals are decent cable.
andyjm said:BigH said:Biwiring makes little difference IMO, in fact it can introduce phase problems, so I recommend not bothering, make sure the links between the speaker terminals are decent cable.
The best links are the flat plates that your speaker was (probably) supplied with. If you have lost these, then good thick cable is an acceptable second best.
Thompsonuxb said:Lol....
If bi-wiring makes no difference what difference will using flat plates or wire make?
