Bi-Amping QAcoutics 1050i with Denon 1910 Help!
I am unsure how to Bi-Amp my Qacoustics 1050i with the Denon 1910
The Denon manual mentions Bi-Amping where as the QAcoustics manual mentions Bi-Wiring.
The back of the 1050i have 4 terminals, LF - LF + HF- HF+
In the Qacoustics manual for Bi-Wiring it states to put one pair into the LF- and HF- and another into the LF+ and HF+
Im not sure if this is correct for Bi-Amping or not?
I am also unsure as to which goes into which on the Denon, I need to put one pair into the Front A and the other into Amp assign but I'm not sure if there is a certain way round for this as well.
So basically not got a clue, any help would be ideal as I am stumped
For bi amping use one set of terminals from the Denon's front channels and connect to the LF on the speaker, and the assugnable/suuround channel to the hf on the same speaker, disconnect the short circuiting cable/brass plate, and set the denon fronts to A+B, that should do,
