Better sound for Sony TV
Hi guys, I recently bought a Sony KDL-40EX503 TV which is spot on for video.
The problem is the sound; it's pretty poor.
My question is what's the most straightforward way of improving the sound without spending buckets of money? I'm not too bothered about surround sound or anything complicated.
I've a Humax, Sky HD and a Panasonic DVD player all connected.
Any help would be appreciated.
Lawrie
A couple of stereo speakers and a stereo amp will do the trick. The amp probably wont have a optical digital input, so you will need a Scart out plug and feed the stereo pair to the amp.
Hi Clare,
Thought aout £160 ish. Does that sound do-able?
Lawrie
This Sharp 3.1 channel sound bar (£147) seems to get good reviews on amazon.
http://www.amazon.co.uk/Sharp-HTSB400-Channel-Soundbar-Technology/dp/B0035ZDPQI/ref=sr_1_2?ie=UTF8&s=electronics&qid=1296499085&sr=8-2
Theres also this PS3 surround bar (£150) which might do the job.
http://www.play.com/Games/PlayStation3/4-/17197652/Sony-PlayStation-3-PS3-Sound-Bar/Product.html?_%24ja=tsid:11518|cat:17197652|prd:17197652
chudleighpaul:A couple of stereo speakers and a stereo amp will do the trick. The amp probably wont have a optical digital input, so you will need a Scart out plug and feed the stereo pair to the amp.
IIRC the 503 has stereo phono outputs on the back so no need for the scart adapter.
Hi guys,
Thanks for all your help; the Sharp Soundbar sounds (sic) like the answer.
Lawrie
Perhaps look for a Sony solution re remote compatibility.
