Hello,
I'm trying to understand what is the best setup I should get to stream best possible quality music to my system.
I currently have Advance Paris A10 Classic amp, connected to B&W 603 speakers and Canton 601 Sub.
Questions:
1) Tidal seems to be the best quality streaming service with FLAC (MQA support ended recently). Correct or is there a better service ?
2) Since I'm planning to stream Tidal FLAC, it should be sufficient to get a streamer that support FLAC, such as Advance Paris WTX StreamTubes (I like tubes sound, my amp is also hybrid tubes one). Correct or I'd be better off getting a streamer that supports also other formats such as DSD and MQA ?
3) Finally, should I connect the streamer to the amp via digital or analogue connection ? My understanding is that via analogue connection the streamer DAC would be used instead of amp DAC and vice-versa with the digital connection
Big thanks in advance! I tried to ask this in my local HIFI shop, but they wouldn't answer unless I buy everything from them. So I'm very much looking forward for some help here.
Questions:
