Best way to connect Asus D2 to CA 540A
I'm currently connecting my Asus xonar D2 to my cambridge audio 540A via a 3.5mm to RCA cable. I'm just wondering if there's a better way to do this? My speakers are CA S30's btw.
I'm interested in how much gain in sound quality i would get from a CA DAC magic as i've heard good things about it but i'm not really convinced.
Or would i be better off using the S/PDIF out on my sound card? Also if i got a CD player with a built in DAC could i use that from my sound card to run my music through the DAC?
Thanks for any help guys.
what I would do is totally different.
I would buy a Squeezebox Touch and use that to play the music on the Asus. it will also allow you to play any internet radio.
then later buy a suitable NAS that you can run Squeezecenter on. (or you can use a powered hard drive attached to the Touch directly).
Bingo you don't need the PC on. and you can play back your music with a player that has DACs as good as if not better than a DAC magic.
