Hi everyone,
I have a bit of a mis-matched system thats been put together over a period of many years and I'm now looking to see where I should take it next.
I'm not really looking to replace the whole system as I actually like the current sound from it, but I'm not sure if I'm missing out on its ability and so wanted to ask if theres an obvious upgrade I'm missing here. My main suspect for an upgrade are the speakers, as these were stock speakers taken from a famly member's all-in-one Hi-Fi system.
Sony TA-FB730R (QS /UK SE) Amp
Marantz CD 6000OSE CD player
Maverick Audio TubeMagic D2 DAC
Logitec Squeezebox (the original old model which doesnt seem to have a name or model no)
Sony SS-LB 355 speakers (these came with a Sony LBT-N355 which is not mine, its owner only uses head phones).
and a PC (it has some horrable VIA on board sound chip which crackles but I use the USB connection from the DAC).
Sennheiser HD 449 headphones
I connect everything to the DAC, PC via USB, CD player via optical and squeezebox via coax.
DAC to the Sony Amp via the normal out (non tube) as its less than 24 hours old still.
I play all types of music, blues,rock and dance and its also providing the sound for movies and games from the PC, so I need to be an all-rounder.
Some extra info in case it helps, the speakers sit under a desk and so the bass gets brought out by it, space apart about 1.5m, the CD player's laser seems to have satrted to wear, as it will on occaision have toruble seeking. Most of the music on the PC/squeeze box is FLAC.
The DAC is a new addition, mainly to solve the PC sound problems, and thats the reason for my renewed interest in upgrading the system. It would appear to me that the DAC is the higher level item at the moment, but I could well be wrong.
Any advice on what would be a suitable upgrade or even just how (badly?) balanced it is currently would be greatly appreciated.
