Best speaker setup for listening to music through PC for around £100?
Jun 14, 2015
I'm looking for some advice on a speaker setup to use with my computer. I've budgeted around £100 although I could stretch that a little if it was necessary. I mainly listen to electronic music so I'd preferentially be looking for something with good performance at the low and high frequencies. I will be using these in a realtivly small room at my desk so they don't need to be hugely powerful.
i've tried doing my own research but there are a huge variety of speakers available in different setups.
What would you recommend for me?
Logitech Z623 (£85)
Something like the M-Audio AV40 suggested above will give better clarity but if you listen to mostly electronic music which has lots of deep bass you will likely find that the separate subwoofer in the Logitech system will sound better overall while still retaining reasonable clarity. Both systems will be a compromise to a degree so it depends on what you value the most - optimum clarity or bass weight and whollop.
