Best earbuds to get
thkui2_3
Hello, I'm new here so I hope I'm doing this right. I was thinking of buying a good pair of earbuds, since I have so many kinds of headphones except that kind. I will use it most of the time for traveling and outside use. I'm confused because each friend telling me to buy different pair.. They suggested me pairs like- iMore triple driver, shure se215, mm70i, momentum.. By the way my max price is 100$ For this pair, if there's something that worth adding a little more I'll be glad to hear.. What do you think? You have any suggestions? Thank you very much for your help!
Soundmagic has some excellent buds in that range, and Thinksound woodies are an even better choice.
I couldn't find a pair over 50$.. Which pair did you talk about?
and what do you think about the shure se215?
This is the most expensive pair of Soundmagics that I could find, and they seem to get good writeups.
http://www.head-fi.org/t/464801/thinksound-thunder-rain-iem-reviews-the-eco-friendly-iem-or-more-wood-note-thunder-will-be-renamed-ts01
https://www.amazon.com/thinksound-Headphone-Enhanced-Passive-Isolation/dp/B002VKFUSY
and all those earphones are the best for the price?
The 'best' can only be determined in relation to your listening preferences (eg neutral, bass boost, extended treble, warm, etc). I have never tried them, so cannot tell you which would be the best for me, or you.
However Dale suggests these manufacturers, and I have selected the models which get the best reviews on headphone forums. Dale is a headphone enthusiast, and it seems like he has tried/reviewed hundreds of headphones, so it is best for him to give you the detailed advice. *smile*
ok
thank's a lot!
Thanks - the main thing is how the forum works. Sometimes a person needs hints to get started, so we will throw out a few brand names to help the person get started. Then when the OP does some research and has more specific questions, those might be answerable too. But if the OP is looking for a personal consultation, that's beyond the forum's ability to help. A lot of times the best earphone in a particular price range may be at or near the bottom of that range. Not usually, but sometimes it happens.
