Best amp for Mordaunt short Aviano 1 under £250
technic123
9
what are the best amps for under £250 to go with MS Aviano 1
i currently have a technics su x320, would there be a noticeable improvement over this amp
CarlDW
23
There are the usual suspects at this price point:
Denon PMA720AE
Pioneer A30
Cambridge Audio 351A
Marantz PM6004 (recently superceded by the PM6005 so there should be some within your budget now)
I can't say if any of these amplifiers will sound better than your Technics amp - they will more than likely sound different, ideally you need to listen to them and take along the Technics for comparison.
In order for bigger improvements you may have to spend more money (Rega Brio-R, Arcam A19 perhaps) or consider 2nd hand.
technic123
9
Hi
thanks for the advice- i would probably go for the marantz pm6005
i mainly play radio 1 songs such as pop and dance etc
im not quite sure what you mean by 'different' to my technics amp
i do like the sound of the technics although it can sound a bit bright and a tad harsh sometimes- also lacks bass when loudness is not on
knaithrover
217
89
18,870
technic123 said:
Hi
I think he meant different as in not the same....
technic123
9
Thanks for the definition of different :roll:
but what I actually meant was what would it sound like different, eg more midrange or dynamic etc
technic123
9
knaithrover
217
89
18,870
sorry that was a little naughty...
Some makes of amp have a signature sound - Marantz and Nad hav a 'warm' punchy sound - Yamaha's have a tendency towards brightness
but all amps are different and react differently with different speakers and of course sources
matthewpiano
494
332
19,270
If you want warm and punchy, with decent bass, then I'd have to say NAD would be your best bet. The C316BEE just falls within budget or, alternatively, seek out a good 2nd hand NAD amp. Very musical kit.
knaithrover
217
89
18,870
+1
mikeparker59
My Aviano 1's were well behaved with my Marantz PM6004. After a bit of a switch around I now use them with my old A&R A60 and they sound very similar with that. They don't have a deep bass but what is there is controlled well. I don't like a lot of thumpy bass anyway. I think they behave well in the midrange, and at my age (55) I don't think I'd hear much top end anyway! So yes I would expect them to work well with the PM6005 too.
CarlDW
23
By 'different' I mean that the overall sound from the amps mentioned may sound different to the sound that you are used to from the Technics, but not always better. You need to demo in order to see if the improvement is worth the outlay.
NAD would also be a good bet, the 326BEE if you can find one in budget.
matthewpiano
494
332
19,270
The 326BEE is a great amp. You'll need to go second hand to get one in budget. Since NAD became exclusive to Sevenoaks there is no price competition and the 326 is firmly 350 quid.
technic123
9
thanks for the more helpful advice
appreciate it alot
am stuck between marantz pm6005 and NAD 326BEE right now
you guys seem to think the nad is a great amp but 'what hifi' seem to rate the marantz higher
currently i have to have the 'superb bass' switched on with my technics otherwise the sound is very weak below 100hz
i was considering a subwoofer, but then realized that my Avianos do actually 'kick' when bass is pushed slightly
gasolin
appreciate it alot
The Nad D3020 has a bass eq on the back (+ 6db)
Considered buying new speakers with more punch then what you got?
CarlDW
23
I would say that the NAD is punchier than the Marantz, and more suitable if you like more bass-driven music.
