Best 22 incher?
New LCD wanted for the kitchen, budget as little as I can get away with TBH, but I'm not interested in a substandard set. It'll be used pretty much exclusively for watching Freeview, but I may add a PVR or DVD player at a later date. Richer Sounds are offering an LG M227WD at £189 which looks decent on paper, but it's in-store only and my nearest branch is 120 miles away. Is this a telly worth pursuing? Any others I should be looking at?
Thanks Andy. I'm looking forward to the 26" test, and was planning to use it for some guidance, though isn't it a safe assumption that a different screen size in an otherwise identical model can mean a lot of difference in performance?
Yes, you're right, the fact that one model at a certain screen size gets a good review doesn't automatically mean that a smaller/bigger model in the same range will perform just as well.
That said, we've had good results with Samsung sets of late and I recently bought a 19in Samsung for my bedroom, which I'm very pleased with. But we haven't tested many 22in models recently, so sorry I can't be more specific.
