wireman:
I pulled out both my PF30 and Tacima to compare over the weekend for a bit of fun. As my mains is generally noise-free, I put the washing machine on (guaranteed to generate a lot of mains noise!), and used a PureAV Noise Sniffer to compare which worked better - the Tacima did a fair job at reducing the mains noise (but didn't eliminate it), but with the PF30 it was eerily quiet! So with that simple yet inconclusive test, the PF30 wins hands down!
Stu31 - you have both the PF30 and PF40 too - which do you use and why?
Does anybody use the HC socket for their AV receiver?
Do you notice any differences between using this HC socket and a normal wall socket?
Hi
I use them both the PF40 is in my av rack with the amp into the HC socket and i'm using the HC socket on the PF30 for my sub.
When i initially used the PF40 on my old onkyo 606 i heard a noticable improvement in music but less so for the home cinema side of things.
I then stopped using the PF40 for a week, while i had it in the shed and sprayed it satin black to match my set up
(looks great now) and really noticed it wasn't there !
Pictures although still good were carrying just a bit too much noise especially the usual suspects on freeview!
Set my new yamaha up on saturday and thought i'd use the PF30 on my sub rather than leaving it in a box (only got it for a spare)
I really cranked it up yesterday had the amp at -15 for dire straight brothers in arms sacd and it sounded excellent really open throughout the range, home cinema aswell so a massive thumbs up from me.
When I get the time i'm going to plug into the normal audio socket and try again just to see if I can hear any differences.
I was going to try power lead upgrades on all my kit but ain't going to bother now as i'm already happy with what i've got.
