balanced interconnects question
are all the balanced interconnects as good as each other or is there a big war with diferent makes tring to out sell each others i ask cose i might buy some and i dont know where to start
Thaiman
360
Balanced cables are the same as RCA, just different plugs being fit, that's all.
ok but hat dosent answer my initial question thaiman
Thaiman
360
[quote user="sex"]ok but hat dosent answer my initial question thaiman[/quote]
I would wait for Andrew then as he would understand your question better than me :)
[quote user="sex"]are all the balanced interconnects as good as each other or is there a big war with diferent makes tring to out sell each others i ask cose i might buy some and i dont know where to start[/quote]
Balanced connections don't really make a difference at line levels. The main benefits are in microphone cables where interference effects and cable handling noises are neatly cancelled by the opposing phases. Unless the cables are very long any will do.
