B&W Zeppelin Air and streaming
one question about the zeppelin air. I will be using my ipad to stream music to it.does this mean i must have a computer constantly connected to provde this.wouldnt be a problem i could just use my old laptop but space is a premium so i would need to rearange things a bit..thanks for any responce
Hi sjared10,
I can confirm that it is possible to stream directly from the iPad to the Zeppelin Air wirelessly, without the need for a computer to be turned on to enable this.
The Zeppelin Air would need to be configured to your network router, but after a simple setup process provided that the iPad is connected to the same network the Zeppelin Air has been set up for, the two devices will see each other and you can stream directly from the iPad to the Zeppelin Air. There is no requirement for a computer to be turned on simultaneously for this to work.
Hope this helps!
