Question B&W M-1 sideways movement?
sparky2k
I'm upgrading an old Jamo system and the B&W MT50 speaker package is on my shortlist. The rears will need to be mounted on side walls as the TV area is at one end of a long rectangular room. The question I have is does the M1 allow any sideways tilt/twist? I see that it can be adjusted to angle up/down but it's not clear whether there's any movement possible in the horizontal plane?
Yes, they are on a ball & socket type joint in the back of the speaker, so you can pretty much angle them wherever you want, then tighten the allen nut to keep them in position.
Very good speakers. Enjoy them.
