B&W CM1 Question
Hi there chaps and chapets ,
just a quick silly question if i may??
Why is the b&w cm1 classed as a monitor rather than a speaker?
Sorry for the daft questions 🙂
[quote user="marcymarc555"]Why is the b&w cm1 classed as a monitor rather than a speaker?[/quote]
Because, for some unknown reason, it seems to add 'credibility' to a product even though it means very little. Neither is it a clearly defined subject (even studio monitors, near or far field differ as night and day unless its BBC specification Rogers/Harbeths or whatever but even there are differences if you compare a modern sterling with an original LS3A. They should measure/sound the same as they are manufactured to original and very tight specification but difference in materials etc make this very difficult). Even if it was a monitor it would mean just about nothing in hifi terms as a flat response ie. within perhaps 1-2db over the entire frequency range does not always make for nice listening, its just helpful for accurate monitoring.
The CM1 is everything but neutral. Its a nice little speaker though.
[quote user="drummerman"]
[/quote]
Hey thanks drummerman
I think i kind of understand you, basically the cm1 isnt a moniter at all, just a speaker that likes the boomy stuff lol??
[quote user="marcymarc555"]I think i kind of understand you, basically the cm1 isnt a moniter at all, just a speaker that likes the boomy stuff lol??
[/quote]
Erm ... yep, in a fun sort of way.
... and I'm sure its only a question of time till some bright spark enters this thread saying every speaker is a monitor ... can't wait.
I can confirm that, its very detailed, with plenty of bass when needed and accurate too.
[quote user="bluetorric"]accurate too[/quote]
So it's a monitor then?
did I really say that?
Maybe not but I did, I'm listening to them now, pretty damn sexy little speaker too..............lol
[quote user="bluetorric"]pretty damn sexy little speaker too..............lol [/quote]
Yep, very good looking
