- Aug 10, 2019
- 2,556
- 5
- 0
Hi, I've got a marantz pm 4001 paired with some elipson horus speakers (small ones).I'd like to upgrade and think it obviously be better to buy good kit bit by bit, spending more over time, than buying a cheaper set up in one go .
My question is will the 4001 be enough to make the 685s sound half decent in the interim (in the reviews it says they'll work with a budget amp - but is mine too budget- its 30w per channel). Or should I be thinking about changing the amp first?
Has anyone tried anything similar or even better listened to them together - any ideas appreciated. Thanks
