I think Series has got the Panasonic 9000 according to his signature. For some reason I always thought he had the 820 Panasonic though, is that you upgrading Series?An HDMI splitter might be the solution for you, to toggle between your player and Amazon stick. Which player have you got?
Yes I’ve upgraded everything, including the 15 year old focal 716 to 2019 716s!I think Series has got the Panasonic 9000 according to his signature. For some reason I always thought he had the 820 Panasonic though, is that you upgrading Series?
Nice! Happy birthday too I just had my 40th!Yes I’ve upgraded everything, including the 15 year old focal 716 to 2019 716s!
yes I have the very expensive panny 9000 and upgraded from the 820; 50th birthday present from the wife.
hdmi splitter sounds like the ideal solution although I don’t want compromise on quality and it must be compatible with the harmony hub, any recommendations.
dont want to upgrade the x4400 really, it’s very good avr!
Cheers, I’ll take a look.This is supposed to work with Harmony hub (search for devices under fivehome):
4K@60Hz HDMI Switch 5x1 FiveHome 5 Port HDMI Switcher: Amazon.co.uk: Electronics
Free delivery and returns on eligible orders. Buy 4K@60Hz HDMI Switch 5x1 FiveHome 5 Port HDMI Switcher Support Auto Switch with IR Wireless Remote, HDCP 2.2, Full HD/3D at Amazon UK.www.amazon.co.uk
