AV RECIEVER SPEAKER OUTPUTS
Have decided to upgrade My Av Reciever And the attached seems to be a popular Choice at the moment ?
Anyway Question i would like to ask is the speaker connection at the moment i have Qed Silver anniversary cables loose wires
Connected to my existing pioneer Unit via spring clips, Reading up on the attached i shows as speaker ouputs connected via
4mm Banana Plugs ?
Does this mean i would have to have replacement Cables with plugs attached Or Be able to buy & Fitt banana plugs to my existing cables ? Or Can the loose wires Be Fitted in the sames existing way they are Just Now ?
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/4448
