AV Receiver with Sky+ HD
Hi
I have recently started putting together my AV kit and am considering which Receiver would be best. I am considering the Sony 4200ES or posibly the 820 but read somewhere that the 4200 needed some updating to be compatible with Sky+ HD which I have.
Does this mean the 820 would not be compatible?
In a nutshell I would like the Panasonic BMD35, Sky+ HD and an AV receiver with initially a pair of Dali Lektor 2s or B&W 680s. I would also use the system to listen to audio so it will need to be 'musical'.
Any thoughts/responses from the AV experts would be appreciated as I am new to the AV world.
I already have my Panasonic 37" PZ81 and Sky+HD and have a budget of £800 for the BD player, receiver and speakers.
I'm assuming you're referring to the Sony STR-DA2400ES and STR-DG820. It's true, there was an incompatibility issue with Sky+ HD at first, but this has now been fixed on both models so either will work fine with your Sky box.
Both units are surprisingly musical for an AV receiver and would make a good choice for your system. You say initially you'll start with a pair of Dalis or B&Ws, but presumably you'll upgrade to a full 5.1 package? Not much point in having a multichannel receiver otherwise!
Thanks Andy
Not greatly in love with idea of 5.1, too many speakers and wires etc although wouldn't rule it out entirely.
If I stuck with just two speakers what amp would you recommend instead?
Well, if you're going to the trouble of getting a Blu-ray player and Sky+ HD, I'd still urge you to go for 5.1. After all, you won't fully appreciate the jump in sound quality on Blu-ray discs or benefit from the multichannel broadcasts on Sky+ HD unless you have full surround sound. Seems a bit of a waste to stick to stereo (although I know one or two colleagues in the office who might disagree with me!).
Yep, I wouldn't upgrade to a BD player if I didn't utilise the surround sound.
R
