Hi everyone, just need a little bit of advice from you all with regards to AV receivers & 2 channel stereo performance please.
I've had the chance over the past year to demo different amps/receiversspeakers as i'm looking hopefully to get either a dedicated stereo setup, or a home cinema setup sometime next year.
Here is what I've found so far :-
1.The best hifi sound that I liked was the Roksan Kandy Amp/CD Player connected to B&W CM8's. Really liked the sound and is within budget. However...Does not cater for home cinema.
2.Had a demo of various different AV receivers in 2 Channel stereo. Here are my findings so far...
Had a demo of the Arcam AVR400, and a few high end Pioneer recievers connected to a 500.00 cd player. Didn't like the 2 Channel stereo sound. Again demoed with B&W CM8's.
2. Tried the Onkyo NR809 in 2 channel and absolutely loved it.
I have been told that Denon and especially Marantz receivers are pretty good when it comes to 2 Channel stereo performance and I will be looking to demo the Denon 3312, Marantz SR6006, SR7005 in due course and see what I think. I'm aware that Denon/Marantz are owned by the same company, however most forum posts online all seem to say that the Marantz receivers sound better, when compared to their Denon equivalents.
I have also had a demo of the Marantz MCR603 with different speakers and absolutely loved the sound. If I could get that type of sound in 2 channel from an AV receiver, then that would be perfect !
I have read a few recent AV receiver reviews on whathifi and they say that the receivers sound good with music too, which is confusing me even more as many others say that an AV receiver can never sound as good as a dedicated 2 channel setup.
What I could do is get the Roksan Kandy steup with the CM8's and then just buy an All in One Home Cinema setup for approx 500.00. That could be one solution, however opinions on the web seem to say that all in one home cinema setups are not the best solution and are poorly specced.
The other ideal soultion is to get a Home Cinema setup which can be used with both music and movies.
I have a few questions with regards to the above though, firstly, if I purchase a receiver for approx 1000.00, which is really the max I would like to spend, how much should I spend on a dedicated cd player? Any recommendations would be greatly appreciated!
Secondly, is a decently specced Blu Ray Player connected to the analog inputs of an AV receiver going to sound as good as a dedicated CD Player ?
And lastly, if I go for the CM8's as the fronts, do I need to match the other speakers with the CM rears, centre & subwoofer, or can I mix & match. The CM subwoofer is very expensive lol.
Just remembered one final point, I could get an AVR receiver, and use the A/B speaker switching, then have the Cm8's for 2 channel and then 5.1 speaker package for home cinema.
Sorry for the long post, but lots of questions/advice needed.
