Av receiver for B&W dm600 S3 5.1 setup
i have the old b&w speakers the dm600 series 3. my setup is dm600 s3 for rear and dm602 s3 for front speaker and lcr60 s3 for center and i am looking for a new av receiver my budget is £500 and i will be using this for 2d,3d blu ray movies thanks
i accidentally made two post can some one please delete the other same post thanks
MrKay00 said:
Hi MrKay00
I know the 600 Series speakers as i used to sell these.
At a budget of £500 Yamaha's RX-V671 will do the trick nicely 🙂
Btw, have you already got a receiver and sub? If so what make and models are they?
All the best
Rick @ Musicraft
thanks for your reply. I have a very old av receiver its a kenwood model krf v5050d i have no sub at the moment but will be buying one of the same model if i can find one. does the Yamaha's RX-V671 have 1.4 hdmi as well thanks
MrKay00 said:
Hi MrKay00
Thanks for your reply and your welcome.
You'll find the RX-V671 to be a worthwhile upgrade and its overall tonal presentation suits 600 Series speakers just nicely 🙂 Yes the RX-V671 has 1.4 specification HDMI's.
Btw, the ASW675 sub woofer will be the icing on the cake. There is an ASW675 on Ebay.UK at the moment.
All the best
Rick @ Musicraft
Hi MUSICRAFT,
do you think i should sell my current setup and get the B&W MT-30 would they be better then the setup i have now thanks
MrKay00 said:
Hi MUSICRAFT,
Hi MrKay00
No. I'll recommend that you carry on using your speakers for a while yet as these 600 series speakers are some of the finest which B&W have produced and are also capable of higher levels of performance then the MT-30. Adding a ASW675 will be the icing on the cake 🙂
Btw, is £500 your limit for an AV amp? The reason i ask is because as good the RX-V671and other amps are at this level however your speakers can benefit further from even higher calibre of amplification. Something worth bearing in mind.
All the best
Rick @ Musicraft
thanks for your reply again. I wanted to stay in the £500 mark but can go over. how much is it and what make and model are they thanks
I would suggest you to try Denon avr 2311 (or even 2310 if you don't need 3D)...it mathes very well with B&W...
Hi hortensio,
Thanks for your reply. But i need the 3d. am using a hd 720p projector that has 3d but will be upgrading to a 1080p 3d projector soon. is the Denon avr 2311 better then the Yamaha's RX-V671 thanks
can some one also please help me with what cables i should get for my speakers at the moment am using them cheap richer sounds cambridge audio symphony 100 or 200 ones not sure which one it was thanks
MrKay00 said:
Hi mrkay00
Your welcome.
Staying close to the £500 mark Yamaha's new Aventage RX-A810 (RRP £850) is worth a look. As good as the RX-V671 is however the RX-A810's overall quality of power and performance are much better which your 600 series will easily benefit from 🙂 Alternatively the recently discontinued RX-V1067, RX-V2067 and RX-V3067 are also worth considering as you may still find these amps at very good prices.
All the best
Rick @ Musicraft
MrKay00 said:
Hi MrKay00
I'll recommend that you should carry on using your existing speaker cables.
All the best
Rick @ Musicraft
Hi MUSICRAFT,
Thank you very much for your replys again. i will be getting the Yamaha receiver gonna look in to the models u have given me thanks again
Hi MUSICRAFT,
i have found a Yamaha's RX-V1067 for £499 should i buy this over the Yamaha's RX-V671. thanks
