- Aug 10, 2019
- 2,556
- 5
- 0
hopefully one of you experts can answer my question...
I have set up my tv on a tv support attached to the wall with the cables running behind the wall down to where my av receiver will be. that is not visible. however after all that work i have just had a doubt as to whether the aerial cable goes directly into the tv ( in which case no problems) or first into the av and from there via the hdmi to the tv... which is the better option... if the latter I have not had an aerial socket installed near the av and so is my only option now to have a visible cable going back upto the tv...
If I connect directly into the tv, then will the av still be able to send the sound out to my 5.1 speakers ( that is, sound from the aerial signal not dvd etc)
