Av amp suited for Boston Soundware xs
If i recall well when reviewed on the magazine they where recommended with the Denon 1910, as they are within the budget, and i think the amp will not overpower the small sats and should give a great sound.
I saw that review myself. Im wondering if the newer Denon 1611 or 1911 would be just as good a match. My budget is going towards the 1611
I don't see why the 1611 shouldn't be fine.
Unless 3D TV is important toy you, have you considered the 1910. This can be had for bargain prices ATM; I suspect similar to the 1611. Even though it's HDMI 1.3 as opposed to the HDMI 1.4 of the 1911/1611, you would still be able to connect a 3D blueray player that had dual HDMI outs ---- one for audio and one for video as are being made by Panasonic. If 3D TV is important to you, then the 1611/1911 will give you full 3D BR player choice.
I Agree with that and to note is that the 1611/1911 seem to have much less input options on the rear panel for some reason. though the 1610/11 would be a great match to IMO.
Im not worried about lots of input options. So the 1611 is looking good and is good for my budget
