- Aug 31, 2010
- 159
- 0
- 0
Hi Folks,
I ran audyssey setup with my Denon over the weekend and have a question about the crossovers it set for my speakers.. It set my Fronts to 60hz crossovers and Surrounds to 40hz crossovers.. from reading the specs of my speakers - the r90hds start and 80hz and the 225hds start at 60 hz.. should i change the crossover settings to these to 80 for each? Also audyssey set my centre channel at -7db.. which is a couple of db lower than my fronts.. so to get clear dialog i have to turn up the volume which gives me sometimes overpowering surround sound.. is the solution to up the centre channel level a couple of db?
Thanks,
Mick
Thanks,
Mick
