What makes you think it will not?Hello all,
The question is simple 🙂
Will it work ?
Thank you
Good choices however I think the Dynaudio deserve an amp with a bit more grunt. The Audiolab was good in it's day and, if in good condition, no doubt it will still perform well today. Synergy is the point lost by many who simply buy five star products and assume they will work well together.Hi, your source components are very good, esp Technics Turntable. I do not know your amp (is it tube or solide state?). Both speakers you select are very good. KEF has more focus on details and "bang"=macrodynamic. Bass is also very good with impact. They are not so easy regarding placement in the room (you have to play a bit and look for optimum). Buchardt are more balanced, less "rockstars/Kef", more jazz and acoustic music oriented. Their bass is deeper and a bit more under control. And I think their 3D sound is more accurate that at KEF. In small to medium room they do not need subwoofer. My choice here will be... Dynaudio Speciale 40. They are like chameleon with very good micro and macro dynamic, very good balanced sound and also bass has power and clarity. Regarding music, they are very universal, not selective. All those speakers are very good ones. But they need excellent amp. Here I am not so sure in your case. BR. Juraj
Hi Laurent, thanks for sharing more info. I think also, that for 10m² will be Kef r3 simply "too much of good things" in bass area. And I see you really love your amp and want to keep it(I like it, I am the same). Now I will recommend new QAcoustics 5040 for your room. These are standmounts for some 800 eur+ stands. There a very good and universal speakers. They are not so demanding on amp like Kef, Dynaudio. Also no issue with your amp. I think this will very good combination, where your amp can shine. I have had Cyrus One amp refurbished "candy". Instead of changing amp I have changed several speakers till I liked what I hear😀. BR. JurajThank you for your answers !
I may give a little bit more of informations:
- The Audiolabs is rebuilt, sounds like new ( almost 🙂 )
- The room is tiny, maybe 10m² (my office). So only bookshelf.
- After hours of reading (and BS), I tend to go with KEF... Dynaudio are out of my league.
. I am looking for a nice sound at low/medium volume wih bass (I am a sort of bass head 🙂), I know that this is going to be hard, in this type of package.
So can the 8000A + Kef R3 Meta on other can give me that ?
Again Thank You for your answers...
Yes Laurent, you are right. Your room is small 10 m². I was thinking about Q Acoustics 5020 standmounts. They will shine also in a small room. BR.@BR. Juraj,
I am not sure to understand... The QAcoustics 5040 are floor-standers, not standmounts ...
Laurent.
