- Jan 16, 2013
- 661
- 3
- 0
Room measures, I actually finally measured it, 19 ft x 14 ft 6 ins, with the TV against one of the "short" walls. Prme seating position is almost exactly half-way down the room, and I've decided to wire for a 7.2.4 setup, i.e. 4 in-ceiling speakers. The two I had installed by the builder, half-way down the room, will remain in place ( a) because they're only $120 a pair (b) so I don't have to explain to 'er indoors (or do) the ceiling repairs necessary if I moved them, and (c) so I'm "future proofed" (ahem). Mostly (b), of course.
The four new speakers will go 1/4 and 3/4 of the way down the room, so that they're equally above-and-in-front and above-and-behind the prime seating position. That's 4 ft 9 inches from the front and back walls in a room 9 feet high at the TV, 8 feet high at the back with two 6-inch steps in the floor. All of this meets the Atmos front-to-back spacing recommendations BTW.
However, the Atmos white paper doesn't give guidelines on how far in from the walls, or how far apart from each other, the speakers should be left-to-right.
Currently, the in-ceilings are 21 inches from wall / ceiling edges to the centres of the round speakers. I think this might be a bit too close to the edges of the room, but they're currently in line with the front in-walls, the positions of which are restricted by vertical wall studs behind the plasterboard, and I'm not sure everything really has to line up perfectly.
The speakers are Yamaha NSIC-800 round jobs, 50 WPC RMS /140 peak rated, 8 inch woofers with concentric tweeters. The OD of the speaker mounting is 10 3/4 inches. They're not titlable BTW, so I can't "point" them towards the centre-line fo the floor.
Thoughts?
Thoughts?
