Atlas Equator or Atlas quadstar; any difference?
peterpan
160
For my system, Denon 1500 amp. and cdp with B&W 684 speakers, i'm looking at the Atlas Equator of the Quadstar. Will there be any difference? Who knows these cables?
I'm also looking at speakercables. No so expensive. Atlas equator 2.0 or Atlas Hyper 2.0?
idc
1,142
117
19,370
Hi peterpan. Have a read throught the following thread re the equator;
http://whathifi.com/Search/Forums/atlas+equator/
As for the Quadstar, a search has found no trace of it here. Since it is twice the price of the Equator you would hope that it would be better. This is now a judgement call for you as to which one to get. If you can get both on trial and then post back to the forum what you think, then at least you will have added to the combined knowledge of the forum. The same advice applies to your speaker cable choice.
