The first.- it is true that they need a very powerful amplification to work well.
The second.- it is true that a high volume is necessary for them to sound good.
I really don't like ATC i personally find them boring BUT that's by design. think of them as a RAW photograph they have no grading or contrast applied they are a tool TBH. And if you really like that then that's fine.
Nopiano is correct don't believe everything that is thrown around. and both your points are kind of correct.
It's not that they play better louder its that they need a healthy turn on the volume knob to get the drivers moving, in turn, meaning you need a healthy reserve of power on tap, so wattage. They will certainly give an amplifier a hard life.
They are certainly not low volume listening speakers the same way for example revel are/is.
If it were me you need to go and listen to them and compare them to more lively designs. Infinite baffle inclosures don't need to be this hard to drive and don't need to be as overbuilt, though out of budget look at the klipsch heresy 1 2 and 3 all sealed and all much more lively.
Are you asking me?Nad amp ?
Nad 3080 comes into my mindAre you asking me?
If I went NAD, I'd go pre and power using the C275 with the matching pre or grab one of there THX monster amps form back in the day
to really take them by the horns, they would give all the control you'd need for the ATC's
I am currently using curved SCM11's and they pair perfectly well with Naim Audio's Uniti Nova.The first.- it is true that they need a very powerful amplification to work well.
ATC Transducer designs and builds monitors. They are flat and honest which reproduce music and movie soundtracks in an uncoloured and natural manner.I really don't like ATC i personally find them boring BUT that's by design. think of them as a RAW photograph they have no grading or contrast applied they are a tool TBH. And if you really like that then that's fine
they didn't impress at all SimpleATC Transducer designs and builds monitors. They are flat and honest which reproduce music and movie soundtracks in an uncoloured and natural manner.
ATC monitors impress by not trying to impress. Simple.![]()
I'm impressedthey didn't impress at all Simple
i can answer your first question.The first.- it is true that they need a very powerful amplification to work well.
but my Denon has 105 watts at 8 Ohms, will that be enough?i can answer your first question.
It is true .
I auditioned a number of speakers in hifix coventry with my old MF amp. At 40w per channel my amp was struggling.
Ample.but my Denon has 105 watts at 8 Ohms, will that be enough?
Your right there.If only it was this simple![]()
Perhaps I should have said, as long as it’s one of Denon’s rather nice Hifi amps and not an old AV receiver?!If only it was this simple![]()
My amplifier is a Denon PMA 920 stereo with 30 years old and a power of 105 W at 8 Ohms and 180 W at 4 Ohms weighing 11 kg, non-AV only stereo.Perhaps I should have said, as long as it’s one of Denon’s rather nice Hifi amps and not an old AV receiver?!
So, exactly as I said originally, ample!My amplifier is a Denon PMA 920 stereo with 30 years old and a power of 105 W at 8 Ohms and 180 W at 4 Ohms weighing 11 kg, non-AV only stereo.
I understand then that they would be enough to move them with ease in my room of 21 square meters, forgive my insistence but when using the translator sometimes I do not understand well.So, exactly as I said originally, ample!
yes with that rating you should be finebut my Denon has 105 watts at 8 Ohms, will that be enough?
