- Aug 10, 2019
- 2,556
- 5
- 0
Hi all, Some advice on a stand for my gear is needed! Would it be acceptable to utilise a pair of Atacama 180mm add-on shelf units as a stand without purchasing the base unit? Does the base unit add anything to the Equinox system or is it just to get you started? Cheers
