Are people listening to music too loudly?
davedotco said:
radiorog said:
davedotco said:
radiorog said:
Cheers DD, yeah just realised my question wasn't specific enough. Your answer was very interesting though, and surprising.
I think want I was wandering was, say I'm listening to a track and the Max dB recorded is 70db, what frequency is most likely to be producing this Max loudness? Or is it a combination of all of them? Thinking now, I may have realised the answer....something comes to mind about something I once heard maybe on this forum, where say one person clapping, producing a dB of "x" , if say 50,000 people are clapping at the same level in a football stadium, the loudness is obviously louder than the single person clapping. I'm not sure of the exact equation for this though, maybe you do?
Does this mean that the Max loudness of a track is created by all the frequencies combined? Although from what you have previously said, you estimate 90% of it is from the bass, especially in dance. It's funny, I think I would have guessed that the midrange would be loudest, but that's prob just me taking the MOR option.
My answer was really a reflection on modern pop music, a solo violin will be rather different an acoustic guitar too, though I suspect the bass power will be much higher than might be suspected.
You also need to be more precise in your language, 'loudness' is an entirely subjective notion and subject to, among other things, the Fletcher-Munson equal louness curves, that may explain why mid and upper mid notes seem more prominent.
Wow! I thought loudness was the actual physical measurement where dB was the unit! Had no idea it was a subjective term (google agrees with you Dave). Learnt something today!
Indeed, loudness is a subjective term if you are being accurate with your language. Sadly any kind of 'science' is deemed uncool and precise language nerdy. All part of the dumbing down of the (non) working class.
There really are just two terms that you need to understand, SPL (sound pressure level, a physical measure of compression in the air) and loudness (an individual, subjective evaluation of the SPL).
Mechanically the ear is a horn, (in reverse compared to a speaker horn) and like all horns follows the laws of physics, the most important one being the simple fact that air does not compress in a linear manner.
High SPL in the ear canal will have a high harmonic distortion for this reason, but rather amusingly if a signal at lower SPL has an inherent distortion of a similar nature, the ear mistakes that for the distortion produced by a high SPL and interprets the lower SPL signal as loud. (though it still measures low SPL).
Take a moment or two to understand that, it is pivotal, and the primary reason valve amplifiers appear to go louder than their solid state equivilents. The ear (ear/brain in reality) is easily fooled in other ways too, for example it is frequency selective, much more sensitive in the mid band than at, say, low frequencies, look at the Fletcher-Munsen equal loudness curves for more on this.
Also the ear has a kind of automatic gain control, ie sustained exposure to high SPLs will cause the sensitivity of the ear to decrease, hence the tempory deafness after a very loud gig. It also explains why, at a party with high ambiant noise levels, turning your hi-fi up so that it is audible results in over driven amplifiers and blown speakers despite it not sounding (subjectively) very loud.
This is all pretty basic stuff, you can go into greater depth if you like but the simple explanations above give a basic handle on what is going on.
The next thing you need to understand is the word 'exponential'.
It is the explanation of why, once you step out of the cosy world of background level music replay, and ask a little more from your system, your power requirements go through the roof.
Save that for another time.
Thanks for taking the time to explain some interesting stuff Dave. It's very interesting how the ear misinterprets low SPL with distortion as high SPL. I'd love to hear this personally in an experimental kind of way. I am OK on exponential as paid more attention in physics classes than most other subjects.
DocG said:
What is that valve amp in your first graph, lindsayt? THD rises sharply at ... 400 W! *shok*
Indeed. It would be interesting to know what amps we're talking about.
Lindsayt, can you provide links?
Glad that you 'get it' most don't.
It explains a hell of a lot about the way hi-fi works, and why high power is more important than you think.
The ear is a funny device, essentially an exponential horn in reverse, as I said above. As SPL increases, the relationship between the (acoustic) power causing the rise in SPL and the measured SPL becomes non linear, in effect high SPLs in the ear canal contain significant types of distortion, mostly low number, even harmonics.
Of course our ears are totally accustomed to this but the result is that our ears interpret such distortion as loudness, not hearing it as distortion at all. This applys to completely natural noises, but when a hi-fi is reproducing entirely natural sounds, some interesting things can happen. The kind and type of distortion added to the 'sound' by a hi-fi system varies enormously, not just in quantity but in quality too.
The ear will tolerate quite high levels of harmonic distortion particularly when it is low numbered, even harmonics but tiny amounts of high numbered, odd harmonics are perceived as obvious distortion, as indeed is crossover distortion in class B amplifiers, intermodulation distortion etc.
In short the annoyance value of the 'distortion spectra' of different amplifiers means that the distortion from some amplifiers may be much more noticeable and annoying than the distortion from others, even though the measured % distortion figures are the same.
This is just another example of the way that subjective evaluations may vary from simple measurements.
If you google "stereophile tube amp review" and "stereophile amp review", all 3 amps are on the first page on the stereophile review pages that come up. Just click on the amps and then the measurement pages for each.
The high powered valve amp was the VTL Reference in tetrode mode.
The low powered valve amp was the Thoress 300b
The solid state was the Arcam FMJ (that got a mention in another thread on this forum recently where someone saw one for sale for £2000 in Italy).
If you click on a few valve and solid state amps you'll mostly see variations on the themes of these 3 amps - in the clipping area.
i've turned down my amp now from 45 to 30 and will try and keep it there see how it is. can range from 65-85db but i dont enjoy it as much.. 🙁 90-95 is more enjoyable but yeah my ears wont thank me in the long run.
Thanks for that.
The argument that's conventionally made for valve amps clipping differently from solid state amps is that the two different designs produce different harmonics when clipping. This wouldn't shown up in THD measurements.
You could have a different 'mix' of the amount and type of harmonics produced, which gives the same THD, but composition, therefor the sound is different. Even so speakers themselves probably produces 'magnitudes' of harmonic distortion in comparison to an amplifier.
matt49 said:
Thanks for that.
Yeah, but when you get to 10%, 50%, 100% 2nd harmonic distortion, it's going to sound wrong. And most valve amps go from less than 1% THD to 50% THD very quickly when they hit the clipping area.
And that's not to mention the non harmonic distortion that you get with clipping that will also make your system sound wrong.
