paulselwood said:First I have listen to you all. Second the dynaudio 2/6 are easy to drive speakers. Third I have 3 demos, with the marantz 610 plus my arcam a19. and last yes I have been reputable stores. All shops do is want your money.
I had all in one systems before, when I live in fat.. Then move house got separates again. The main reason I wanted demo on marantz 610, if that some time in the future if I move, to a small flat I know that the marantz will work well with the speakers.
Also if you do a search marantz & DM 2/6, people do have that set up and are happy with it.
So why do you think the dyn will not work well with the marantz.? ? ?
Paul
Ignore the naysayers...
If you've heard the Marantz 610 with the Dyn DM 2/6's and you think they're a great match, then that's all that matters!
I, in the past, had the MCR603 and had with with all sorts of speakers from M/A BX5's to B&W CM5's to KEF LS50's to Neat Motive 2's and it never skipped a beat. A great sounding all in one system with plenty of power to drive those speakers and it'll drive the Dyn's well also
Fully agree re the all in one systems, if they can do all you need and sound great to boot; then go for it!
