Assuming that when it launches, Apple Music Classical fulfils its promise of providing a much better metadata set for classical music, and lossless hi-res audio, many of us will be faced with the fact that Apple Music, unlike Tidal and Qobuz, isn’t built in to any third part streamers other than Sonos (I think).
Which means that a lot of us are going to be trying to find the best (i.e. not airplay) way to get apple’s classical music to our audiophile amps and speakers,
Assuming I start with an iPad (the story will be quite similar with a Mac or iPhone with some specific differences but I will be using an iPad Pro) it seems to me that there are two main ways of doing this:
1) To use a USB external DAC (I have an A&K AKHC3) plugged in to the iPad and then take analogue out from the AK headphone jack via a 3.5mm jack to RCA cable, then feed that in to my Cambridge Audio EVO 150 as a selectable Aux In source. So the A&K does the digital to analogue.
or
2) use a USB C to USB B cable (would I need any particular spec fo this cable I wonder?) to connect the iPad to the USB Audio port on the EVO. So (AFAIK) the EVO’s DAC would be doing the digital to analogue conversion.
Both the DAC in the EVO and the DAC in the AK HC3 can more than cope with the highest resolution files Apple music has to throw.
Does this sound sensible? Or am I missing something obvious?
or
