Hello all,
I have just recieved my new HTC One and put some music onto it forgetting that about half of my itunes library is apple lossless files. Could anybody recommend a converter which I could use to convert the files and to make them smaller - down to something like a 256kbps itunes file would be good.
I have looked at apps from the play store which will play apple lossless on the phone, but I'd rather do the conversion first and then have a seperate folder of tracks for the HTC sync manager to sync from.
Thanks for your help
Edit -- Just realised I could probably do this on itunes itself, is there an easy way to export them all out of itunes at the same time? Or at least keep them all in a single playlist on itunes without having them appear with everything else?
