Anyone tried these interconnects
I,ve had STRATOS 3 interconnects for 7 years now, has anyone tried these, are they any good, should i change?
Thanks all
johhnyjazz .... there are good but there is always better ... so if you are happy with your system, don't change ...
If you wish to experiment and upgrade, you need to get some more expensive ones on loan from a hifi shop and test them on your system at home, then decide for yourself (can be a costly business)
check WHF's best buy section and read their reports/tests to get ideas of what may be suited to your budget
but also remember that the more expensive are not always the better sounding
Thanks Dim-Span, thought that would be right. Have tried online, the only info i can get is that the military use them so must be good.
They were purchased along with the SUGDEN BIJOU system in a high end dealer in glasgow. The Stratos is what he used to demo them as well as a lot of other equipment. The speakers are only 3 months old and are Spendor A6, on the end of Atlas hyper 3 cables, i think the whole system sounds fantastic, so as you say if your happy then don,t change.
Thanks for your advice. John
johnnyjazz:
the military also uses landrover?
Hi Andrew, nice to speak to a pro, like you personally don,t think anything wrong with landrover. Do you know anything about Stratos cables.
Thanks john
