anyone have ONKYO 875 with KEF 3005SE speakers ?
trapster
hi guys
just got a set of
KEF 3005SE speakers
about to get ONKYO 875 to power them
just wondering if anyone has the same set up,and if so is it a good combo?
or does anyone have any opinions on the set ?
is the amp too powerfull for those speakers ? or about right ?
]or any other thoughts ?
  • I have an 875 with 3005se, it works well. have the crossovers set at 80Hz for the speakers. The power of the amp is fine for the speakers. The setup is ok for music, but I use an Arcam a32 and MA speakers for that as it sounds better. Make sure you have firmware 1.07 or above on the AMP. I updated mine with a laptop.
  • Overall its a good setup.
thanks for the fast reply 🙂
i have this setup for tv/films/bluray not for music so thats not a problem
can you explain what crossovers set at 80hz means ? sorry new to all this lol
is this a setting on a amp ?
and what other settings are there,and also if i did not set it to 80hz what happens ? lol
sorry to sound a bit dumb but i just dont know what you mean.
but thank you for the info so far 🙂
Below 80Hz, the sound is sent to the SUB. Its in the setup menu, but the auto setup will do it all for you.
ÿ
My ÿOnkyoÿsettingsÿas follows ÿfor ÿa Room 3.5M x 3.5M
Front 80 HZ ÿ ÿ -3.5dB
Centre 80HZ ÿ -6.5 dB
Surrond 80Hz ÿ ÿL = -6.0dB ÿ ÿR = -7.5dB
LPF of LFE ÿ 120Hz ÿ -7.5dB ÿ ÿÿ
ÿ
Sub set to 0dBÿ
well i dont have the onkyo amp yet
but my kef sub is set to the following
power = auto
phase = 0
base boost = + 6
