Anyone bought a LG50PQ3000 ??????
I am on a tight budget but want a big screen......what do you think of the LG and is it worth considering ??????
From what I've seen it's alright for the money. I'd also check out the Panasonic 50X10 at a similar price though. But yeah, plenty of shops should have this TV in stock so go and see it if you can. If it's hooked up to a bad feed ask somebody to plug something else into it.
It is on the John Lewis website for £699. Ideally I was looking for a 50" TV......dont think I can demo?? Also I presume there are a standard fit for a wall bracket ????
Yes the brackets should be universal. By demo I just meant you should go to a shop that sells them both and compare. My opinion of which I prefer might be completely different to yours, so it's really best just to check them both out if possible.
