I got the new epg (seems OK) but what the heck is wrong with lip sync? If I watch SD or HD programs - no problem but if I watch recorded programs, SD are OK but HD lip sync is horrendous. The adjustment of up to 200ms is no use, I need whole seconds. It is so bad that I can't even tell which way to go and I don't fully understand the range. I presume you start at 0 seconds delay of the sound and then progress to 200ms delay - OK but then it loops???
I don't want to delay the sound - that makes it worse (I think) - I want to delay the images or go to minus values with the sound. What can I do because it is just unwatchable?
Thanks in advance.
Thanks in advance.
