Al ears
Electro said:Oran said:Thanks for all the advice folks.
Budget is not set in stone. My starting point is to explore the sub £1000 options.
However if there is good reason to go up to the next level then I will consider that.
The Abrahamsen is an interesting option which I did not know about.
Im guessing that it not possible to audition these in the UK?
If you contact Colin about a demo of the Abrahamsen ( details and contact info in the link I posted ) or even possibly a home demo I am sure he will do his best to help you out, he has helped many people on this forum already so I am sure he will do the same for you .
He is based in Cheltenham, Gloucestershire.
It would realy be worth your time and effort imo. *yes3*
Seconded. I believe they have a home trial period but basically you are buying on faith. Believe me it's worth a try. If I hadn't I wouldn't have ended up with the amps I currently own.
Don't forget Hegel either as they have an incorporated DAC that is better than you currently own, and are more 'auditionable'.
