Ampl problems with bass and treble with Mission speakers.
Hi Can anyone help me?
In order to get the bass what I want from my speakers (any speakers really) but mine are the Mission M35i, I have to turn the bass up (full) on my amp (Denon) and lower my treble otherwise its too tinny. I am only just turning the volume knob nearly a quater turn so there is pleanty of volume usage left. I know that their is a bi-wiring on my speakers if i needed to do anything, but I think that this is only for those who can really tell the difference. I don't know what to do,Can anyone help me sort this?
Is it the amp? Is it the Speaker cable? All my seperates are new last year (2009)
Many thanks Dodgey
Not a great deal of help, but if it is of any consolation, I have a pair of Mission M35's. These were the model previous to yours (the "i" denotes-improved) or not as the case might be. My Missions are bi - wired and bi - amped, with a NAD 370 supplying the high frequency terminals L+R and a NAD 270 supplying the low frequency terminals L+R.
With the set up above the bass is not what I personally expected it to be, and the bass will only seem perform to how I like it if the system is played loud (which of course it will do very easily). However, this in practice is not ideal.
I am not sure if this is a particular trait of these speakers, but it might pay you to audition some other speakers, as this is the route I am now going to take.
Hope this has helped!
dodgey40:
Many thanks Dodgey
Apologies if this is a silly question, but as you mention Bi-wiring, I'm guessing you are only single wiring? in which case, is there a link in place between the two sets of speaker terminals?
Unless you expect more bass than what's actually in the recordings (many people do), this is most probably an acoustic problem.
Try moving your speakers around a little.
Wiring has certainly nothing to do with it -- unless you use very thin cables with bad connections...
Fahnsen:
...unless there's no link between the woofers and tweeters and he's connected only to the tweeters.
dodgey
You shouldn't lack bass with the M35's, so the only thing I can think of, short of a faulty driver or two, is that maybe the speakers are out of phase - check the positives are going to positives and negatives to negatives - it's a very easy thing to get wrong when wiring up! If this is the case, it will sound thin and a little weird to.
