Best intergrated amplifier around £500-£600 to power a pair of Q acoustics 3050i's in a mid sized room
What amp do you currently have?Best intergrated amplifier around £500-£600 to power a pair of Q acoustics 3050i's in a mid sized room
You asked the same question recently. More than enough good suggestionsBest intergrated amplifier around £500-£600 to power a pair of Q acoustics 3050i's in a mid sized room
Ideally 2 tape inputs,cd,tuner,phono and a couple of aux inputs if possibleWhat inputs do you need in said a amplifier, I mean what will your music sources be?
More information required before a choice of amps can be offered I feel, nobody here can tell you what's best just offer options.
I did but my tablet crashed spectacularly and I've lost all suggestions,sorryYou asked the same question recently. More than enough good suggestions
Amp?
Hi audiophiles I'm due to upgrade my amplifier from a beautiful old sony ta fb740r to a new intergrated amplifier.i currently run a rega planer 3 record player and an old mash technics cd player as well as cassette decks and a tuner so will need plenty of inputs. I run Q acoustics 3050i...forums.whathifi.com
Hope you can see the link now. There's a whole plethora of new and used amps for you to choose from.I did but my tablet crashed spectacularly and I've lost all suggestions,sorry
Thank you so muchHope you can see the link now. There's a whole plethora of new and used amps for you to choose from.
Mmm... at 2x23 watts into 8 ohms not sure it'll be powerful enough to drive the QAs to their full potential.
And neither having the connections the OP needs.....I know I sound like a broken record but ...
Your budget is 50 quid short of an Audiolab 6000A or Cyrus ONE Cast.
Both very able.
2 tape inputs? Really? Can't you just use aux for a tape deck?Ideally 2 tape inputs,cd,tuner,phono and a couple of aux inputs if possible
Not if you need a tape loop.....2 tape inputs? Really? Can't you just use aux for a tape deck?
again it doesn't have a tape loop if that is what the OP means by two tape inputs (one is an output)Anyway, for a completely biased subjective recommendation, the Denon pma 800ne (I think it has enough inputs). I recommend what I know and enjoy.
why two tape inputs? Do you mean a tape loop?Ideally 2 tape inputs,cd,tuner,phono and a couple of aux inputs if possible
Luckily the forum itself didn’t crash, so all the answers are here for you to see with another device.I did but my tablet crashed spectacularly and I've lost all suggestions,sorry
Not sure I've ever seen a modern amp with 2 tape inputs.Ideally 2 tape inputs,cd,tuner,phono and a couple of aux inputs if possible
Yes, your ideal would be severely limiting your amp choice.Ideally 2 tape inputs,cd,tuner,phono and a couple of aux inputs if possible
Me too,a tape loop is a different matter but even that is rare now.The only amp I can remember with 2 tape inputs, I could be wrong, was a rubbish brand my mate owned, that was Sherwood. It was horrible, more wooley than a field full of sheep. Even my old 1970s built Pioneer would laugh in its face.
Otherwise I'm struggling to think of a domestic amp with 2 tape inputs.
