My set-up is just an Arcam rDAC hooked up to a laptop and a Marantz PM6004 amp with a set of Monitor Audio BX2 speakers and I'm having the fairly serious issue of only having the left side play any audio while only hearing the occasional faint crackle out of the right. This is almost certainly an issue with the amp as the problem persists when I switch to headphones and when I change the source.
The issue had occurred before briefly but it seemed to go away after I turned the set-up off for a little while.
I have an idea of what may have caused the problem, a few weeks ago I let my roommate use it with their laptop and I didn't tell him not to turn it up too loud so when I came back the volume dial was at about 12 o' clock which is way past the reasonable level. Could this be the reason for the problem and are there any ways to deal with this? It's pretty upsetting not being able to use my equipment properly.
