Amp and CD player isues
Is it best to match your amp and cd player??
I cant decide which ones to choice if this is the case.
My budget is around £600
The thoughts i have had so far are....
Audiolab 8000 - amp can be got for £300 but cd player is expensive
Cambridge audio azur 540
Marantez 6002
Harman Kardon HK980 - only based on looks and name have no information about them.
They will be paired with B&W 685's and idially should look good but sound is obviously the most important thing.
All opinions would be massivly appreciated, should i match the amp and cd player or will seperate work just as well,
If so which sould i look at and listen to
can't give you any suggestions on the players/amps mentioned as i've not heard them but i think matching them is purely down to preference. i prefer my kit to look the same, but i think it can apparently also help take the hassle out of system matching.
the mag did a round up of one make systems a couple of months ago. you may be able to find the reviews on the site. Other wise i can happily dig the issue out and give you the round up.
i have nad c542 and c320bee with some b&w 601's and loved the sound. so maybe you should stick the current nad offerings into the mix too.
thanks, ill look into the NAD's
Has anybody heardany of the amps and has an opion on them??
The Marantz combo of the PM6002 & CD6002. They are great with the B&W 685's are are very smooth sounding.
