I bought a budget system twenty years ago (Nad 302 amp, Mission 760i speakers, Marantz 52mk2 cd player). I added the recommended accessories (better interconnects, speaker stands and rack) and the sound was reasonably good. I could see the flaws, but wasn't too bothered - I was into music/listening to the radio more than the hifi.
Now I rarely listen to my hi-fi. Since I had 2 boys (now nearly 7 and 5), I just don't have time. Moreover, my elder son managed to break the CD tray mechanism. The only way to open it is to gently ease the tray out by finger tips! Also finding anything I like in my music collection is difficult. I can never find what I want, particularly since music is located across two rooms and has my wife's music mixed in.
I'd really like to get back into music and got an ipod touch the other day. I like listening to radio programmes on iplayer, tunein radio and also have some stuff on itunes. The plan is to play this through a DAC using Apple Airport Express.
The Audiolab 8200CD looks ideal for this. I can use the CD player to replace the broken one and the DAC for streaming from my ipod. I also plan to hook it up to my PC so I can start storing CDs as ALAC files and play them through the DAC
So far so good you might (or might not!) think. However, spending £700+ on this item sits a little uncomfortably with me. I know my existing setup won't do it justice. I'd have to upgrade the amp/speakers in due course to get the real benefit. What sort of budget due I need to put aside for this? Second-hand stuff is an option I'd consider too.
Your thoughts and advice are welcome. You can tell me I'm mad to go down this upgrade path too...
